OT: SAC as a physical mixing console
As a point of interest, I have two questions:
Q1: If SAC was a physical mixer, just how good would it be "sound-wise"? How would it compare to the other "giants" - such as Yamaha, MIDAS, and so on.
- If, as I understand it, and I do stand to be corrected here, as SAC does not have any I/O, then Bob would be required to design one? Correct? If so, it would be interesting to see what he would come up with.
Q2: If SAC is just as good - or even better as I believe it is, would, or does the quality or inequality of the I/O have any effect of the quality of the SAC engine itself?
- For example, if the quality of the ADA-8000/ADA-8200 and RME combo already produces the output it already does, would the use of other, even more expensive I/O actually diminish, or even have a detrimental effect on the quality of SAC - as it is!
I do hope that I have asked these questions correctly or appropriately? I look forward to your responses.
Re: OT: SAC as a physical mixing console
Quote:
Originally Posted by
Q1: If SAC was a
The audio engine is world class and I do not hesitate to say competitive with any physical console, Midas, Yamaha, Digico, Avid, Soundcraft, Studer, etc. etc.
The I/O has no effect on the engine. It does have an impact on Latency, Noise, and general sound quality in as much as there are pre-amps and converters involved.
The better the preamps and converters the better and/or more accurate the input to output will be.
Philip,
Thanks for the reply.
When you are referring to the"audio engine", what - specifically, is that audio engine?
How would this audio engine equate to a component of a physical console?
Philip,
The audio engine refers to all of the signal processing that occurs inside the computer between the AD and DA converters.
It includes all of the things you visually do in SAC from the top of the each channel strip to the output of each master channel.
EQ, Gates, Compression, Effects processing, Aux sends and summing, channel volume and summing, etc, etc.
Well, you can say that SAC is everything that in a 'physical mixer' is located behind the pre - amp and before the output - jacks.
Tomy
TomyN
Tomy
Actually -- between the associated ADCs and DACs.
