Just to respond to your thoughts here....
I don't think that really adds all that much to the cost, if any added costs at all. Even if the outputs are XLR, you still have to patch them right? That means you still need some cable to go from a female XLR to whatever connector is used on the next device in the chain, whether that be your amps or whatever. An XLR to XLR snake is no cheaper than a 1/4" TRS to XLR Snake. Now you're current cabling might be all set up for XLR so you see it as an added cost and that makes sense. But if you're building an all new rig, the over all cable costs won't be any higher. Or not significantly. I won't argue that I would rather have XLR outs as well.
But if I'm putting a system together for a client, I'm not going to mess around with ADA8000s and telling them they need to keep a spare around because they will need it at some point and/or add on voltage dropping devices. Most clients I think you could justify the extra costs and heck, most clients are not going to know there is a cheaper option if you just spec Presonus.
And most of the ones that do will likely know enough that if you simply say I really prefer you not go with the cheapest of the cheap for your own good.... well they'll understand why.
It seems that as typical, Behringer got just about everything right on these except using quality components and making them reliable! For some of us anyway this is just a touch more important than having a convienent connector on the back.
