SMAART or Systune with SAC
Read a few posts from waaaaayyyy...back about folks attempting transfer function programs like SMAART and such with SAC. Curious to know...is anyone running SMAART and using it with SAC to optimize their systems? If so...are you running SMAART on the SAC Host? Or do you run it on a separate Laptop? If Laptop...what are you using as an Inteface?
I like the idea of being able to run SMAART on the SAC host and thru my ADA8000's. I would only be using it for system alignment and would not require it's use during a show. Wondering if SMAART would step all over SAC....
-SAC,SAWStudioLite,Midi Workshop,SATLive, Reaper
-SAC Host (24 channel): Various Laptops via Digiface into APPSYS Adat extenders into (3) ADA8000,(2) BCF2000 controllers, 1x64 resolution
-SAC Host (32 Channel): Intel Core 2 Duo E8400 3.0Ghz , 4 Gig DDR/800mz RAM, ASUS PK5PL-CM MotherBd,XP Pro SP3, RME Raydat, (4) ADA8000's
-SAC Remote: Various Tablets via AMPED Router
-SAW Host : Asus Laptop, i7 12g RAM
