Re: Wireless issues / SAC remote lock-ups
Originally Posted by
gdougherty
Before you change channels, download inSSIDer and scan for local networks. Look at where the other networks are and pick a channel that doesn't have much competition. 1, 6, & 11 are often recommended but I've also found some of the mid-points to work so the main body of my own network spectrum isn't overlapping with neighboring networks.
Does inSSIDer serve the same function as NetStumbler? I've downloaded NetStumbler but haven't used it yet.
Thanks for the tip,
Ira
Currently using:
T43p Thinkpad w/XP SP3 for FOH, Subs and Front Fill Mixes (20% CPU load);
T500 Thinkpad w/Win7 SP1 for 6 Monitor Mixes (15% CPU load)
Running at 2x32
2 Digifaces, 1 w/CardBus, 1 w/ExpressCard
3-Octamic-D for mic inputs - using the dual outputs to split the ADAT signal to the Digifaces;
1-RME ADI-8 Pro for all FOH sends; 1-RME ADI-8 Pro for all Monitor sends;
