Results 1 to 3 of 3
    Default combining Digi9652 and HDSP9652
    hello all
    I have 1 HDSP9652 at the moment and works fine
    now I can get a Digi9652 for cheap,
    so question is:
    can I combine these two, so I can expand my channels to 48i/o
    and will this run stable?
    at this moment my HDSP9652 runs stable on 2x64
    when I ad a Digi9652 will this be the same?
    or will i get more latency?
    if it is possible, can I ad another Digi9652 to this?
    so a total of 3 cards.
    greetings
    janneman
  2. Default Re: combining Digi9652 and HDSP9652
    You can't combine them to run at the same time within SAC as the DIGI and HDSP cards uses different drivers.
    905
    thanks for quick answer
    so I will look for another HDSP9652
    greetings
    janneman
