A man is being pursued by a deadly hunter, and needs to cross a wide river. He runs to the river bank and there are two boats moored at the riverside. He asks each in turn, 'I need to cross the river, can you help?'. The first says, 'Yes, of course. Look at my boat. I built it myself. I've been navigating these waters for over 15 years. I've experienced everything the river can throw at me. I've carefully designed this boat to be perfect for the fast flowing waters, the rocks in the shallows, the crocodiles and the storms, you're welcome to travel with me. But you have to trust my skill and my craft'. He goes to the second ship. 'Look at my boat' the man says. 'It's beautifully finished, it's huge, it has a bar, a dance hall and and comfortable sleeping quarters. I know about rivers, honest. Check out the fairy lights and the happy passengers'.
Dominic
Thanks for the story.. but you'd have to explain what it has to do with the topic?
The question at hand was weather the track number display could be relabled without actually reordering the underlying tracks.
The answer to that question is yes. It doesn't require object programming, just a simply table to abstract the displayed numbers from the actual track IDs.
In fact, half of that work is already done, as the track labels are already a field associated with the track ID.
Add an additional field/variable for the track number label and almost like magic, the tracks could be displayed in numeric order from top to bottom, without actually changing moving the track info to a different ID.
Ok... sarcasm mode off... obviously it still takes some time and effort and coding to do this, but it doesn't require changing object oriented programming or adding more tracks, or really any significant change to the underlying framework.
It does affect the screen display routines and the move track functions as they would have to be modified to do the display label re-ordering.
As for weather this is worth the time and effort on Bob's part, only he can determine that.
This why I was thinking if it was easy to not display the numbers, then it might be a good compromise. I don't really use the displayed track numbers for anything, but when they show out of order I "pay more attention" than I need to.
David Benkert
Do the fairy lights scare off the crocodiles? Prolly not huh. Happy passengers though till eaten. I'm with you Dom
