Saw Studio and Waves 8
Hi All,
My name is Arjan and I run a masteringstudio in the netherlands.
I am new to this forum but I use Sawstudio a lot (since 1994).
Has anyone experience using SAWSTUDIO 4.9 and Waves plugins version 8?
Right now I use Waves version 7 (via shell2vst) and this works.
But before I update I would like to know if anyone is already succesfully using waves 8 with Sawstudio 4.9.
Regards,
Arjan
Re: Saw Studio and Waves 8
Yes, i´ve got it working for a few days now. Was pretty dissappointed first because waves dropped direct x support on the road somehow ( i´ve upgraded from 5.0 without realizing it so my old session edl´s are mainly unusable now because i used waves direct x plugs a lot ) and also the waveshell does not work directly in Sawstudio.
I also found shell2vst the only solution to be able to use at least the vst´s again.
cheers
Arno Jordan
Tags for this Thread
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
