Results 1 to 8 of 8
    Oct 2005
    Bainbridge Island, WA
    2,064
    Default WiFi Signal Strength Meter?
    Does anyone know of a small meter that could be left open on a SAC Remote to indicate signal strength of the WiFi signal? As you roam a venue, it would be helpful to know if you're in danger of losing your WiFi connection.
    Currently using:
    T43p Thinkpad w/XP SP3 for FOH, Subs and Front Fill Mixes (20% CPU load);
    T500 Thinkpad w/Win7 SP1 for 6 Monitor Mixes (15% CPU load)
    Running at 2x32
    2 Digifaces, 1 w/CardBus, 1 w/ExpressCard
    3-Octamic-D for mic inputs - using the dual outputs to split the ADAT signal to the Digifaces;
    1-RME ADI-8 Pro for all FOH sends; 1-RME ADI-8 Pro for all Monitor sends;
    Jun 2010
    Baltimore, Maryland
    402
    Default Re: WiFi Signal Strength Meter?
    Quote Originally Posted by IraSeigel View Post
    If you have an Android phone, "there's an app for that".
    7th Voice FOH/Mon/Sys Tech
    www.7thVoice.net
    www.reverbnation.com/7thvoice
    SAC Installation:
    Dell Optiplex 990, Intel i5/4GB RAM
    3xMOTU 2408, PCI-424x card, 6x ART TubeOpto8, 2x Motormix
    SAC Portable Rig:
    IBM ThinkCentre M50 3.2GHz/4GB RAM
    2x MOTU 2408/PCI-424x card, 2x ART TubeOpto8, 2x M-Audio Profire 2626
    Yamaha Promix01 controller, EWI Tourcase
    CUDJ-P-22.
    Greensboro, NC
    1,867
    I found http://download.cnet.com/WIFI-Signal...-10663562.html on Google. I don't know how good it is - there are a fair # of bad reviews. If you're on Win7, I believe there's a Widget to do it as well.
    -Craig
    http://www.metageek.net/products/inssider/
    Not really "small", but it works very well, and gives you an idea of what is out there...
    Cheers.
    "while(!asleep()) sheep++;"
    Carlo.
    Aug 2010
    Albuquerque, N.M.
    1,105
    Quote Originally Posted by kruntz View Post
    I was going to recommend NetStumbler until I saw this. This looks like a good little app to have in your SAC arsenal. I would install it on my laptop, which is usually a remote and rarely a host.
    DF
    http://soundaddy.com
    Intel DG965OT Motherboard (11/17/08) - Intel P4 LGA-775 651 (Cedar Mill) 3.4GHz CPU
    2.0GB 800Mhz RAM - 40GB Intel X25-V SSD - 500GB SATA "Spinner"
    RME HDSP 9652 (x2 - 1 spare) - Behringer ADA8000 (x5 - 2 spares)
    CM MotorMix (x3 - Host system) - Behringer BCF-2000 (Remote system)
    I use an app on my Android phone
    Douglas Grimm
    FOH/MON Engineer
    +1 to MetaGeek products. Their WiSpy is an often-used tool for my residential installations, and makes appearances at professional events and installs as well.
    -Jesse
    Exclusive Installs
    RTFM!
    Feb 2009
    Westminster, CO
    2,460
    You'd want to use something like inssider. A smartphone app will show you the strength on the smartphone but that won't necessarily match the signal strength achieved by the antennae on your remote.
