I have the Redline Reverb in VST format, it is installed on the host system as well as two remotes of which one is a laptop. If I am using one instance of the reverb there are no problems but if I add more than one like for instance one for drum verb and one for vox verb the issue starts.
Here is what I found:
If I open a mix file that has two or more instances of the Redline Reverb the remote session will crash as soon as you right click the live button.
If only using one instance all is fine.
My current work around which seems to work so far:
Save the mix file with only one instance of the reverb and then after opening the mix file and going live you add the other instance or multiple instance and it seems to work ok.
This is the 112db Redline Reverb. I would only wish this could work better because this is by far one of the best reverbs that I have heard.
James "Bubba" Sanderford
