Finally!
Ok here is how I solved the mp3 or direct audio stream into SAC with 00% process power usage![]()
What u need is VirtualAudioCable - nonfree
or an onboard integrated soundcard
Asio4All drivers - free
Winamp VST bridge plugin instaled into Winamp
and Warmhole2 vst - freeware plugin
For testing,Instal the demo version of Virtual Audio Cable and the ASIOO4All drivers
Also instal VST bridge and put the Warmhole into SAC vst folder and copy that plugin into winamp so that it could use it also.
Open winamp,and in the preferences select DSP/VSThost/ load DLL Warmhole
on the warmhole plugin select a name - NIK and pres the start button.Adjust the latency to 1000 or even more so you could be sure you dont get skipped buffer.
On the winamps output in the prefs.select Virtual Audio Cable 1 for the output.This way you won't be using any audiocard and all audio will be happening virtually.
Open SAC,load tyhe vst plugin Wormhole into a channel and select FX for input on that channel.Pull the fader up as the naster too.Select from the CHOOSER dropdown menu on the right side of the plugin the "NIK end" option so you could define that the pligin should be the end of the audio chain.Also define the buffer 2000 or as you wish...
As you press play in Winamp, the music will apear on the master bus forcing you to smile
The same can be achived with using a simple onboard non conflicting audio card and in winamp selectiong it as the main audio card,so that SAC could use the RME drivers or whatever cards u are using.
That's it...
If you can't get it work I will up some pictures so it will be much easyer.
All the best,
Nik
