Re: VST to DMX plugin? Controlling light from the audio console
I've used dmxis with cubase for a live act. It uses midinotes to control scenes.
So i dont know how you want to use it in sac?
Now i use Martin lightjockey in the background .it can play audio by itself and program a show on it.
Or with midi notes, it can also sync on miditempo or audio input.
Its also easy home programming without the real fixtures because it has a virtual show designer.
Sac monitor system/ Lenovo T400 8400 core2duo 2,4Mhz with 4Gb ram. RME Fireface 800 64x2 buffer. 2x behringer ADA8000, one behringer 8 chan. phone amp. 2 iem300 in ear sets all with fischeramp beltpacks in a 6 HE case, behringer BCR2000 for monitor mix
