Just Picked up the slate VTM and VCC, anyone else using them with SAWStudio? Having some issues with the Plugin window sizing, anyone else?
Carey A. Langille
Producer/Engineer
Ocean Sound Productions
www.oceansoundstudio.com
Creativity at the Speed of Sound
I hope this can be fixed.. on VCC, you have a channel plugin and a mixbus plugin, when you put the channel plugin on a channel, it appears fine, but when you use the open wide function arrow at the botton, the VST host window doesnt open big enough to see it all ( bob, is this something you have preset to a maximum size?) and when you hit the arrow to contract it back to the smalle size, the VST host window Shrinks to about 1/4" so you cant see anything.. I notice that in Sawstudio, the vst shows up in the MIDDLE of the host vst window, but on other daws, it shows up on the LEFT side of the Host vst window... Any ideas Bob??
VTM seems to work fine, EXCEPT i dont see the Reel animation.. Reels are suppose to start when the host starts playing back.. This doesnt happen in Sawstudio, but it is working in 2 other DAWS that i use.......
Carey A. Langille
Producer/Engineer
Do they have a demo and does it show the same issues... with that, I may be able to see what it is looking for to work properly.
Also... make sure to try it with the Always OnTop option in my vst window canceled... sometimes that can block different operations depending how they handle their window operations.
Hey BOB, heres the Link to the DEMOS page for ya.. Thanks for looking into this issue.... Maybe this will shed some more light on the VST Beast as it is! I will also try the Always on top selection and see if that changes anything....
http://drumclassroom.net/demos/
Carey A. Langille
Producer/Engineer
Oops... ilok2 required...
Angie Dickinson Mickle
The Studio
http://www.avocadoproductions.com/ze.../recording.htm
Chris' tribute site
http://www.micklesong.com
Carey A. Langille
Producer/Engineer
I'll have to look further... no guarentees.
Problems here, as well.
Ken
Intel P4 3.0 4gb Ram
Motu 2408 X 2
Ada 8000 X1
8 channels of Seventh Circle Preamps
