Randy you are correct about the sync when running each unit as a unique SACRemote system but that is what I have been doing. I am using the buttons on the C4 as a midi 'learn' remote but without the scribble strips working- just memorizing the positions. I am usually looking at the screen anyways. I can run 64 channels with a main control and 7 extenders although I rarely run more than 24/36 channels total.
If you get the API working I will be a happy camper. I bought SAC mainly as an in ears mixer which gives me all those stereo busses to work with. Everyone gets their own stereo mix. I have gotten pretty good with the bank switching so sometimes I do a job with only the main MCU. This works ok but I have always wished for a solution to have the extenders work with the main control for the occasion where it is needed. I also run Nuendo 5.5 and all of my extenders will work there. I can't imagine working with just the 8 faders in that program. So I'm going to do a big +1 to your post based on the need for this feature. BTW I have 2 MOTU midi timepieces which are inexpensive and give the ability to run 16 unique instances of 16 channels each so i COULD run all 64 SAC channels with unique hardware for each channel on just one MTP. The old stumbling block of not enough midi channels to run multiple Mackies for SAC is no longer an issue. I will be your first volunteer beta tester.
Jim Stafford
