Hello
I am having an issue with one of my motu 324 pci cards. I have been using it with success for over 8 months with an ibm 8171 (XP, 1 GB ram, 3.0 ghz) with a 2408 mk1 and 3 ada8000's.vThat is, until last week when I started to get a beeping noise when passing audio. I have moved the ada's and changed the 2408 for another, changed out the audiowire,re-installed the drivers and the SAC software, and I continue to get what sounds like a beep noise only when audio passes. I have an identical rig that was my spare unit but now has been pressed into service. It is working at 1X32 with no issues. The rig in question will work better at 2X128, but went the buffer is reduced, the beep noise is more evident. I found that this forum and others can be very helpful and I read them often, but I cannot seem to correct this issue. Thank you in advance for any helpful advice.
Salsa Dave
Chicago Area
