I've heard this "sky is falling" whining regarding Bob's software for the last 18 year. Meanwhile, I and many others have continued to make a living using SAW and now SAC. I wish everyone would stop complaining and just get to work!
Angie Dickinson Mickle
The Studio
http://www.avocadoproductions.com/ze.../recording.htm
Chris' tribute site
http://www.micklesong.com
As usual, a simple question turns into a ****ing Flame war.... Why do i waste my time.....
And YES i have looked for a motherboard that has Thunderbolt ( which i stated in my original message) and XP drivers.... = ZERO, Maybe its an XP thing and thunderbolt... i dont know.. Guess i dont really even care now....
Carey A. Langille
Producer/Engineer
Ocean Sound Productions
www.oceansoundstudio.com
Creativity at the Speed of Sound
Just asking out of idle curiosity....
Why do you need Thunderbolt for this particular machine?
Carey, my suggestion... don't waste anymore time and money dicking around with XP machines. I have run SAW just fine on my 2 systems with Win 7. It is time to move on from XP. Yeah OK... maybe the Code runs better on XP... but I recorded a small concert on my laptop running SAC and SAW with a firewire interface and all was fine.
I would not bother with XP because not ony do some boards not support it but if you look at driver support for interfaces and the like, many new ones also do not support XP, same with other software and plug ins... I know ... why would you ever need anything Bob didn't create?
But if you care about any other software, it is time to move on.
Richard B. Ingraham
RBI Sound
http://www.rbisound.com
Carey,
If you like Win 7... install that... if you feel Win 8 is cool, install that... either will be just fine with SAWStudio... just make sure your soundcard has drivers for whichever you decide to use.
You can use any motherboard which has your ThunderBolt if that is what is important to you... its all good... start building.
I was going to say something, but decided that I will just sit this one out.
ooo, look.....a chicken....
Ben Farmer
Omaha, NE
ETCP Certified Entertainment Electrician
It may be that you can squeeze more out of an XP system and it could feel like you're downgrading by going with a recent OS. But, for most of us the SAW + XP system had an excess of power. For me there's peace of mind with getting a Win 7 rig going, so I'll trade in a little power that I wasn't even using. I do understand that low latency based systems would be more of reason for worry. (I like to run at a comfy 1024 here).
Just curious, but I assume you veterans can fire up some of the old versions of SAW (SAW Pro?) even on the new OS's without a full recompile? Pretty amazing if so. I do wonder if and when Windows will eventually change something enough to break SAW, and what that would be...presumably something with the graphics. I don't lose sleep over it though.
That's my concern...I run SAC at 1 x 64 because we use IEM's and prefer to run SAW at 2x64 . Haven't tried SAC/SAW on the Win 7 or 8 systems....little gun shy after all the reports I've read.
-SAC,SAWStudioLite,Midi Workshop,SATLive, Reaper
-SAC Host (24 channel): Various Laptops via Digiface into APPSYS Adat extenders into (3) ADA8000,(2) BCF2000 controllers, 1x64 resolution
-SAC Host (32 Channel): Intel Core 2 Duo E8400 3.0Ghz , 4 Gig DDR/800mz RAM, ASUS PK5PL-CM MotherBd,XP Pro SP3, RME Raydat, (4) ADA8000's
-SAC Remote: Various Tablets via AMPED Router
-SAW Host : Asus Laptop, i7 12g RAM
Just wondering... how hard would it be to run some tests and see what you get? Seems to me that while the processor load may go up a bot in 7 compared to XP, if you have a newer machine you also likely have some power to spare. It certainly wouldn't hurt to just run some test by just talking into some mic and/or running a CD player into the system.
Worst case you find out 7 won't work and you keep what you have.
Richard B. Ingraham
RBI Sound
