Re: UPS advice please
Originally Posted by
Eric White
Got bit tonight and lost power when a building switched over from line power to generator. That really got me to thinking about how many gigs I've had to deal with this kind of issue and really need a UPS.
What are you guys using. Here is what I am looking for -1000-1500va , 2u short (15" or less) ,true sine output, not modified sine and would also like the online type.. Any recommendations? This needs to fit in my host rack that is 17" deep.
Thanks for the advice.
-Eric
You really don't need anything the size or specs your asking for.
You need to keep the computer running, not everything else.
Small power spikes/dips and short outages can easily be handled by a basic 400-450va small office grade UPS.
The computer system doesn't really care if its true sine wave power, or that its double buffered.
Bear in mind that even comparatively small higher grade units like an APC Smart-UPS 1500 RM 2U are not going to meet your space requirements. They are too deep 18" and weighs 60+ lbs. The APC unit also does not supply power until tripped (its not double buffered).
I don't think your going to find anything shorter than that, as these units are designed for Server Closet use, not small rack live audio road travel.
I have a small 425VA Cyberpower Unit that can easily power my SAC rig and monitor for 4-5 minutes without any problems. http://www.newegg.com/Product/Produc...82E16842102116
If the power is down for more than that, you don't have a show either way.
