Results 1 to 10 of 15
Thread: MWS and SAC
    2,623
    Default MWS and SAC
    Is there a way to have MWS output show up in SAC?
    I have a number of MIDI files I would like to load in MWS, which is connected to Kontakt, then link to SAC for audio ouput.
    Please advise.
    Default Re: MWS and SAC
    Please advise.
    I'm not a SAC user, but...
    MWS doesn't output audio, just MIDI. That MIDI can drive VSTi's in SAW, which would output audio just like any other source in SAW. I think there's a proprietary audio link from SAW to SAC, right? That would be the ticket, I think.
    brettbrandon Guest
    Please advise.
    Is Kontakt running as a vsti in SAW or is it running independent?
    Brett
    2,623
    As a VSTi in SAW.
    I think I "figu'd" it out...you have to use either the Input Chan Play Tap At PRE-PATCH option or the Input Chan Play Tap At PST-FDR option.
    That seems to do it...though not sure exactly how...yet.
    Thank you...
    You can also use hardware midi ports and cables or a virtual midi cable to connect the MWS midi outs to the vsti plugs patched into SAC... this has the added advantage that the plugs are always live while the SAC engine is live.
    2,623
    You can also use hardware midi ports and cables or a virtual midi cable to connect the MWS midi outs to the vsti plugs patched into SAC... this has the added advantage that the plugs are always live while the SAC engine is live. Bob L
    Sound like a great idea!
    However, am I able to use the MIDI ins and outs of the SAME RME HDSP 9652 to accomplish this?
    brettbrandon Guest
    I was going to make Bob's suggestion of loading it in SAC and use a "Virtual Midi Port" to communicate between the two.
    Brett
    EDIT: Here's a link for a free virtual midi cable.
    http://www.midiox.com/index.htm?http....com/myoke.htm
    Yes, you can use the same RME card for both ins and outs.
    2,623
    Quote Originally Posted by brettbrandon View Post
    I was going to make Bob's suggestion of loading it in SAC and use a "Virtual Midi Port" to communicate between the two. Brett
    A "heads up" on how to get this all working?
    PS: I "figur'd it out". Thanks!
    May 2005
    Darling Downs Qld Australia
    1,022
    Thanks for the info Dell and others. I need that right now.
    Cheers - mako
    Denis Hillman
    Queensland
    Australia
