Re: Two IEM questions- OT
Matt brings up a very good point, and you should reconsider using RF IEMs for those that aren't mobile (drums, keys, etc). Much less problems and probably better fidelity.
As to your scanning question and worrying about choosing the right frequencies: The Sennheiser software (as the Shure) will choose the proper open frequencies in a "Group" or "Channel". You should (almost) NEVER mix frequencies in different groups; the software calculates the intermod potentials and will not recommend frequencies that conflict. As you said, getting a switch to aid in the scanning (and setting) of all the transmitters is a HUGE help and benefit. Then you only have to retune your receiver-beltpacks manually (the really REALLY expensive Shure stuff does all this automatically now).
As to your question about the drummer's mix: I've done many drummers (JD Blair with Shania, Jack Dejohnette, e.g.) who have only asked for a single overhead and kick for their kit. Some have also asked for one of those "butt-thumpers". Or only a DPA or similar quality lav that they wear, to pick up the whole kit. As someone else suggested, wait for the drummer to ask for stuff - don't put it in there without being told to. Ditto for the rest of the band. Use little - if any - gating. NO COMPRESSION on anything, for anyone.
Currently using:
T43p Thinkpad w/XP SP3 for FOH, Subs and Front Fill Mixes (20% CPU load);
T500 Thinkpad w/Win7 SP1 for 6 Monitor Mixes (15% CPU load)
Running at 2x32
2 Digifaces, 1 w/CardBus, 1 w/ExpressCard
3-Octamic-D for mic inputs - using the dual outputs to split the ADAT signal to the Digifaces;
1-RME ADI-8 Pro for all FOH sends; 1-RME ADI-8 Pro for all Monitor sends;
