I use Saw Studio Basic. Is it possible to copy the effect attributes of one track and paste to another?
Thanks!
Thanks!
I don't know offhand, but you should be able to find out for yourself.
Try left-click/hold and right-click on an "empty" space in one of your mixer view channel strips. If you see a menu with "Save To" and "Recall From" choices, then yes - you can do so.
Basic does not have the chan store/recall feature... but you can still transfer plugin settings from one plugin to another by using the save and load presets feature on the plugins themselves.
