I think the 'cleanest' mixdown is one with no clipping, regardless of SoftClip implementation. A recorded, clipped signal is not a happy thing. But the Levelizer could be used to preclude the possibility of clipping in certain mixdown situations. The trade-off is brick-wall limiting instead of clipping -- which still sounds amazingly transparent up to several dB of gain reduction for most program material in my experience. This is why my standard mix template has a Levelizer set to limit at 0 dB patched post-fader everywhere, and SoftClip turned off. Even so, those are measures intended to help me out when headroom runs out and my options are limited (no pun intended). I still try to keep my mixer gain structures under control as to limit (no pun intended) the use of this limiting.
