Re: Melodyne 2 and Saw 5.3
Originally Posted by
Grekim
So far so good! Only about an hour of intense use, but no crashes. I have not experimented with live mode, but in normal mode you need to keep SAW playing while Melodyne is processing after a transfer. If you don't, nothing crashes, but Melodyne doesn't finish processing. So, placing a region downstream or maybe live mode is the solution there. Anyway, it's exciting for me since I have not tried the two together in a year or two.
IIRC, Melodyne 2 works fine (and as you describe) in SAW 5.2. The only thing is that you can't hear the notes when you move them around (re-pitch them by dragging vertically) in the Melodyne window. But I don't know if you can do that with the plug-in in any DAW host, so...
(You can do that in the stand-alone version.)
