Monitors of FOH with minimal Sound Check?
Starting to get a few more gigs that are taking place in a working Sports Bar / Restaurant. type setups. They frown on a lot of "Noise" outside of the actual gig so you've got 1 or 2 songs max. in which to sound check the band.
In those situations...what do you focus on....getting the monitors set up or getting the FOH sounding great?
I find it's tough to be concentrating on watching the band while I'm trying to dial in the House sound.
Do you do a quick balance of the FOH so it doesn't sound too out of wack and then concentrate on getting the Guys monitors set up?
Or do you shut down the Front End to minimize the noise in the room and work with the guys on their Monitor mixes?
I've got a Tablet so moving around the room is not an issue.
How do you guys handle this type of situation?
-SAC,SAWStudioLite,Midi Workshop,SATLive, Reaper
-SAC Host (24 channel): Various Laptops via Digiface into APPSYS Adat extenders into (3) ADA8000,(2) BCF2000 controllers, 1x64 resolution
-SAC Host (32 Channel): Intel Core 2 Duo E8400 3.0Ghz , 4 Gig DDR/800mz RAM, ASUS PK5PL-CM MotherBd,XP Pro SP3, RME Raydat, (4) ADA8000's
-SAC Remote: Various Tablets via AMPED Router
-SAW Host : Asus Laptop, i7 12g RAM
