Motormix (x3) losing sync - possible fix
Been having a problem keeping my trio of motormixes connected to SAC Remote for any length of time. Sometimes they'll go a couple of hours, sometimes just a few minutes before becoming unresponsive. It was to the point that I had stopped using them becasue even with one or two it would drop out.
I thought it might be the MIDI interface, so I tried a different one (built into a Motu 8pre I have around, which it turns out isn't compatible with Asus I3 laptops, anyway...) and still had the same problem. I noticed that when it was happening, the laptop was also becoming unresponsive for a moment before resuming activity. Then I noticed AVG was popping up scan notices shortly afterwards. Disabled AVG... system ran for a couple hours, then went down again (again, with a glitch in the laptop).
Just for shiggles, I tried turning on Realtime priority in the Remote menu (and verified that it does actually change the priority). So far, it's been running nonstop for 6 hours with no glitches. I'll leave it overnight. If anyone else has been having problems like this, I'd appreciate some verification if you have time in the next couple of days... I've got to go out with the rig for two weeks starting Sunday and hopefully this fixes it.
TIA
BE
System Load - 25-30%, at 1x32
BE your sound.
