SAW Sub group / Multi Main outs....?
I have an question as to whether it's possible to achieve this work flow....
I've created some subgroups for Drums, Guitars, Backing Vox etc....so that I can apply specific Sub Group Mix Buss processing unique to each type of Instrument/ group. I am currently sending these Sub Groups, as well as individual instrument tracks, to 3 outputs: (1) feeds my main Studio monitors, (1) feeds a headphone output and (1) feeds a set of consumer grade Book shelf speakers that I use to check my mix against.
I am Using Mix Bus Processing on these main outputs...Compression, EQ and Tape emulation. In order to hear what the processing is doing I need to apply the same Mix Buss processing to each output...which obviously is causing a hit on the CPU and RAM usage.
I also want to mix against several Reference Tracks similar in style and tone to the genre of the track I'm mixing.
However I do not want to have the Mix Buss processing affect the Reference tracks...they've already been thru that process as part of their recording.
So.....What I want to do is to be able to take my individual tracks and the Drum Bus, Guitar Bus , Vox etc....and send that to (1) Master Subgroup fader.....to which I will apply all my Mix Bus Output processing.
I would then like to send THAT master subgroup to my 3 Monitor/ Speaker / Headphone outputs. I would also send the Reference Tracks directly to the Monitor/ Speaker Headphone outputs...bypassing any Mix Buss Processing.
It;s this last routing setup that I'm suspecting may not be possible within SAW.
Your advice and perspective would be appreciated.
-SAC,SAWStudioLite,Midi Workshop,SATLive, Reaper
-SAC Host (24 channel): Various Laptops via Digiface into APPSYS Adat extenders into (3) ADA8000,(2) BCF2000 controllers, 1x64 resolution
-SAC Host (32 Channel): Intel Core 2 Duo E8400 3.0Ghz , 4 Gig DDR/800mz RAM, ASUS PK5PL-CM MotherBd,XP Pro SP3, RME Raydat, (4) ADA8000's
-SAC Remote: Various Tablets via AMPED Router
-SAW Host : Asus Laptop, i7 12g RAM
