Re: SAC remote
Originally Posted by
Mattseymour
If this is something you want then SAC is not the right product for you. There are plenty of hardware alternatives that offer this, there will also probably be software alternatives. I would agree this is the way things seem to have gone but it's unlikely SAC will ever get this ability.
The way I dealt with this was to a have a laptop on stage running SAC remote. I gave this remote monitor only control and let musicians use it to balance their monitor mix (IEMs). That worked well. A BCR2000 along with the laptop, labelled up, meant it was one press to select your monitor mix then you've got turny knobs to adjust.
Didn't SAC's original vision have each musician controlling his own mixer/mix with a discrete laptop? Would there be no way for Bob to do the same thing with SAC remote on discrete tablets? Seems like it would be a current-day update to the original vision.
