Results 1 to 2 of 2
    Default How to use shell2vst foe waves plugins
    Hi
    I have downloaded a demo of the waves CLA plugs and they won't work in Sawstudio.
    I tried the writing an INI file using notepad but no luck.
    I've seen Shell2vst on one of the post on this forum but I'm a bit lost.
    Has any one used this or had this issue?
    Do I copy the shell2vst into the vst plugin folder in saw or somewhere else?
    if someone has a step by step how to, that would really help.
    Thanks for any help in advance
    Greeny
    Sawstudio, mws,
    Default Re: How to use shell2vst foe waves plugins
    Quote Originally Posted by greeny View Post
    Hi
    Greeny
    Sawstudio, mws,
    hi, put the shell2vst in the VST plugins folder, then drag the Waves shell to it. It will open a folder call Waves with your plug-ins in it. You can move them to the VST Plug-ins folder (out of the Waves folder) or make .ini files.
Tags for this Thread
