Re: Automation with UAD plugs
Originally Posted by
MMP
AFAIK, there is no calculation for offsetting automation if the latency occurs pre fader & no calculation for latency in the placement of overdubbed audio.
It's been a while, but I think I determined that if I add up the reported latencies of all pre-fader plug-ins for a given track, and then offset any affected automation by that total value (moving said automation later in the track), it all works out. Or am I misunderstanding you?
And you're saying that that doesn't work for offsetting overdub audio after tracking?
