Originally Posted by
Stashu
Carl,
One thing you'll notice about WLM and the other Calm Act meters: They force you to do the right thing in mixes and volume draws. Which makes the use of a squishing limiter obsolete. Or, at least not the go to plugin for all ills.
When we started using the WLM for network shows, I noticed myself simple getting the levels in range, using clip gain for the loud an quiet parts to match the target level, and using the limiter just to catch the light overages.
Listen to the mixes on Discovery. They are as loud as the Act allows and clean, clean, clean. All the VOs fit in one range and the mix is full without a lot of thumbs to your remote volume action.
I think my mixes have never been better. I just switched my old radio station 'clipper' brain off and record and mix with the end product in mind. There is a whole lot less of the 'fix it in the mix' commandment.
By the time I've finished editing the VO track to the WLM, I'm on to the FX music, mix and rarely have to visit the VO again. Everything else will be wrapped around it.
It's a fresh new way to use the old basic concepts of levels and sound in general.
