Is it possible to use Behringer S16 S32 midas DL32 via Appsys as interface for SAC
S16
http://www.music-group.com/Categorie...es/S16/p/P0AJA
S32
http://www.music-group.com/Categorie...es/S32/p/P0BMC
DL16
http://www.music-group.com/Categorie...s/DL16/p/P0BI3
DL32
http://www.music-group.com/Categorie...s/DL32/p/P0BMD
SD8
http://www.music-group.com/Categorie...es/SD8/p/P0BKI
SD16
http://www.music-group.com/Categorie...s/SD16/p/P0BKE
for Gaincontrol in SAC or VST there is this tool from Thomas Neumann SAC GAIN
http://www.sawstudiouser.com/forums/...highlight=gain
or for Gaincontrol via BCF2000 and BCR200 via MIDI direct on the MIDI in and out of the S16
https://www.music-group.com/Categori...CF2000/p/P0246
https://www.music-group.com/Categori...CR2000/p/P0245
the coolest way will be complete support of the Behringer Xtouch
https://www.music-group.com/Categori...OMPACT/p/P0B3L
https://www.music-group.com/Categori...-TOUCH/p/P0B1X
the Sound could be transmitt via ADAT Appsys Adat extender
http://appsys.ch/en/products/extende...2b-adx-64b-pro
also the Midi signal
or i think over AES50 with the appsys mutiverter
http://appsys.ch/en/products/extende...iverter-mvr-64
transmit into Dante and
have Dante in the computer Via Dante virtual soundcard
https://www.audinate.com/products/so...nte-controller
put the output via Dante into the amps
http://www.amphenolaudio.com/product...r/amphe-dante/
could this work in real
and would it be better or cheaper than
have some ADA8200 with gain mod and with a Raydat card and a Remote PC in the Rack and Remote FOH with BFC and BRC and Touch Display ?
