Hi,
the x-touch (only the 'big-one') supports midi over network. So there is a midi-rtp software running on the host which makes the host available via midi over Ethernet.
The x-touch uses the rtp mode and is connected to the network also used for my kvm - device and for the remote(s).
If you just want to replace a BCF, you can use Midi (either 'nativ' or via USB) also.
Tomy
Well,
it works using LAN. I think technical it's a USB over Ethernet system with a USB Display converter. I like it very much, becaus I can operate this on a normal network, that can carry the rpm-midi data, the remote-data for one SAC remote and sometimes even Art-Net.
It uses the pc's network card and some software on the host, and a small hardware device on the client side.
See http://www.win-star.com/eshop/goods.php?id=146 for details
Tomy
