Results 1 to 3 of 3
Thread: RCA CAMBIO 10.1 and SAC-REMOTE
  1. Question RCA CAMBIO 10.1 and SAC-REMOTE
    Anybody using one of these to run SAC-REMOTE?
    Name:  2017-05-17 08_02_00-Amazon.com _ RCA Cambio 10.1_ 2-in-1 Tablet 32GB Intel Quad Core Windows 10 .jpg
    Default Re: RCA CAMBIO 10.1 and SAC-REMOTE
    I got one last year to use as a remote for setting monitors during soundcheck. Worked great!! Then after a Windows update, it wouldn't book correctly. Since I didn't have time to fix the problem and they were so cheap, I just bought another. And I was not happy with the new one. The USB died almost immediately and the display doesn't turn off when in sleep mode. Because of the experience with the second one, I really can't recommend it. Though it is cheap enough to take the chance.
  3. Default Re: RCA CAMBIO 10.1 and SAC-REMOTE
    Quote Originally Posted by Angie View Post
    Thanks for the reply.
