Results 1 to 7 of 7
  1. Default Hot Keys or hot clicks
    Do you guys know of any onscreen software that has hot click options, where I can program in Undo's, Redo's, emulate right click, etc., so that I can activate these commands with one touch.
    I fired up my touchscreen TV on SS yesterday, and with the use of a new third party onscreen keyboard (smaller than the windows 10 version), it made it really easy for me to navigate around everything.
    The only thing that would make this an almost perfect setup is if I can have on screen preset click commands.
    Default Re: Hot Keys or hot clicks
    andysharifi,
    Could "AutoHotKey" not be used in such instances.
    Melbourne, Australia
    409
    Logitech G110 or G510s have programmable keys that will allow you to do exactly what you want, G110 has 12 (x3) and G510s 18 (x3)
    (I think they are obsolete now but you might be able to find one somewhere)
    if you are interested I can let you know what I programmed the keys to do,
    also autohotkey will do what you want but you have to use the normal keys
    3rd option is an X-Keys keypad, this works very well to!
    Robert V.
    www.shinustudios.com
    www.art2ear.com
  4. Default Re: Hot Keys or hot clicks
    Thanks for the suggestions. I was able to find a neat little program that does exactly what I want. I included a pic of it. I'm still working on adding more buttons.
    https://cdn.pbrd.co/images/gJFYEgA9y.png
    Quote Originally Posted by andysharifi View Post
    and what is the name of this little program??
    Saw64, SAC64 DP, Live, Cubase, Logic Pro and LUNA
    http://www.jillandrich.net
    2,431
    Yes, I am interested too.
  7. Default Re: Hot Keys or hot clicks
    http://hot-virtual-keyboard.com/
    its a sophisticated program. Rather than create a keyboard from scratch, make a copy of one of the existing ones and just edit it. This allows you to keep the shift, ctrl, alt buttons on latch mode when pressed.
    But the possibilities with this program are endless. You can even replace the keys with actual photos of real buttons.
