Hi all,
I am dusting off some legacy projects and using the import dialog in SS to update some old SawPro EDLs. I am using the guide in section 3-14 in the manual for importing. Most of the time, I am getting predictable behavior: After clicking a few hundred times, SS will put empty regions on the MT and a list of regions in the Regions view. I then use the file dialog to remap. Easy-peasy.
But I have an EDL that is putting regions in the Regions View but no regions on the MT. Is this a corrupted data problem? Double-clicking the regions in the Regions View goes to the correct location in the SoundFile view so I know that the EDL retained some of the info correctly.
So that leaves me with the challenge - how do I resurrect the session? How can I get the regions to go to the right track and location in the MT?
I seem to remember - wasn't there a command that would take a region in the Regions View and place it into the MT according to its metadata? Or am I remembering that wrongly?
Thanks!
Eric
