Help with New Build
I am a SAC owner and SawLite owner since 2009... I am replacing a computer and wanted to get some help from the forum as I am a music person more than a computer person.
You will probably recognize the motherboard I am using as it is the same the Bob uses and recommends, but my Windows XP installation is crapping out (blue screen of death) half way through the installation. I removed the SSD drive I listed below tried again using a "regular" drive and it got further in the process but the results were the same.
There is a strange power cycling the seems to be going on when I fire things up, almost like a car that won't start. Crank, pause, crank, pause, etc for 15 seconds then it loads up.
I was hoping to get some help from some of the more computer savy people on the forum. I've put together these systems in the past and everything just loaded right up.
System Components:
ASUS P8B75-M/CSM LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Intel Core i3-3240 Dual-Core Processor 3.4 Ghz 3 MB Cache LGA 1155 - BX80637i33240
Crucial BX300 240GB 3D NAND SATA 2.5 Inch Internal SSD - CT240BX300SSD1
Crucial 4GB Kit (2GBx2) DDR3L 1600 MT/s (PC3L-12800) Unbuffered UDIMM Memory CT2K25664BD160B
Any direction is appreciated.
SAC 48 Channels - SawStudio Full - MIDI Workshop
