Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Default Re: Wav to uLaw conversion
    Hey Bill,
    Better late than never (haven’t been on here in a while). In SF, the uLaw is buried in the save as WAV. I’m doing this from memory right now, but where the PCM option pull down is, there are other settings, including uLaw.
    Scott
  2. #22
    I have found the perfect setup to create really clean sounding uLaw files for phone systems. Using Audition, match the settings you see in the picture below. For the sample type, I choose 8000 Hz Mono, 16-bit instead of 8-bit. The final WAV file will still come out as an 8K, 8-bit uLaw file. But if I select 8000 Hz Mono 8-bit, the sound of the file is far worse with lots of hiss. Choosing the 16-bit option clears that up for some unknown reason. Hopefully this helps those creating uLaw files for phone systems.
