Results 1 to 3 of 3
    Default Convert 32-bit audio to 24-bit
    I did a forum search, but didn't find anything. Search terms are too short, I suppose.
    I got a 32-bit audio file from a video client for noise reduction, etc. SS won't open it and the only program I have that will open it can convert it only to 16 bit. I understand that 16-bit is plenty good for a poorly recorded audio for video track.
    What are you using to convert from 32-bit to 24-bit?
    Thanks,
    Ian Alexander
    VO Talent/Audio Producer
    www.IanAlexander.com
    Jun 2004
    Central Point, Oregon
    1,960
    Default Re: Convert 32-bit audio to 24-bit
    Sound Forge.
    Mar 2015
    Alberta Canada
    79
    Audacity - it's FREE....it will read RAW-PCM, as well as many other formats. According to SAW documentation, SAW will read 32bit floating point files, which are still 24bit with an extra 8bits tagged on for an extra 2db of headroom. I suspect your 32bit file may be a non standard format...
    Laughing Crow Studios
    Alberta Canada
