Page 10 of 23 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 228
  1. #91
    2,431
    Default Re: SAWStudio (and Plugins) 64 Bit Bug Reports!
    Not that it’s much help, but Trilian is working fine here in SAW64.
  2. #92
    OK, got Trilian to work on windows 10 computer.....but I see in the MWS, the cursor follows playback until I zoom in just enough to see the bars 1,2,3,4, etc...and the cursor no longer follows playback. It vanishes.......??
    Saw64, SAC64 DP, Live, Cubase, Logic Pro and LUNA
    http://www.jillandrich.net
  3. #93
    Oct 2005
    Tehachapi Ca.
    571
    Anyone else notice that "Multi track soft clipping" doesn't seem to work? I can get hard clipping in both on and off positions.
  4. #94
    Good catch... fixed for the next update.
  5. #95
    Oct 2005
    Tehachapi Ca.
    571
    Cool, glad to be of help! Thanks.
  6. #96
    The vanishing scrolling cursor/wiper while playing back a midi track zoomed in seems to be on my windows 10 machine....works fine on other windows 7 computer.
    Wonder what that is??
  7. #97
    It appears Win 10 display graphics are a lot slower than Win XP, 7 or 8... still looking into it to see if there are any settings that can be adjusted to speed them up.
  8. #98
    Bob,
    WinaeroTweaker might help here... [click_me]
    What I also have to be helpful is to remove all Windows 10 apps.
  9. #99
    Bob,
    OK....I will give this a go...
    Thanks!
  10. #100
    richswit,
    What I suggest that you do, is to first export the default configuration...so that you can import this exerted file if things do not go as you wish.
    After configuration, I then export the configuration - saving it to a data file.
