I posted this a while back and got no replies at all....
Anyone experience this at all??
"I'm getting some crashes when I go from one layer to another while playing. Second layer is empty. I sometimes switch to layer 2 to quickly remove a track from the mix and put it back. Not when stopped as far as I can tell. Hasn't happened with no plugins. My current edl is using Wavearts TrackPlug 5 on two tracks, plus Boz Labs's PanKnob and The Slate Digital VerbSuite Classics on return track 1. The MAAT Dynamic range Meter is currently on output track 1. That's all as I am just starting out on this project and it only consists of a few tracks. I suspect it is one of the plugins causing the issue because I couldn't get it to happen on a fresh edl with no plugins.
I created the same edl over again and added all the plugs one at a time, ending up with the same setup and no problems. As soon as I brought up the AUX 1 sends on the tracks so I could get some reverb, the problem reappeared. Then I turned off the aux sends but still have the problem. Weird, right? Tried removing all the plugs, still crashes.
Removed all regions then put them back and NO CRASHES!! Saved the EDL. Added the plugs back in, still no crash....yet.
Something is corrupting the edl somewhere along the way, right?
Ideas???"
