Page 20 of 23 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 228
  1. #191
    Default Re: SAWStudio (and Plugins) 64 Bit Bug Reports!
    So, I thought that I would give this a "shot"...
    1. My non-tweaked office system
    2. i5 with 16GB's RAM
    3. ZOOM UAC-2
    4. SAW v1.1a
    5. Add SoundFile To MT at 44.1, 16bit
    6. Enable Dither Type 1 to Type 3, OK, CPU1 at 2%
    7. Enable Dither > NonCorrelated L/R, OK, CPU1 at 2%
    7. Enable Dither > Random with Type 1 to Type 3, BufferOver Dialog is displayed, CPU1 spikes
    * Repeat the above, SAW will eventually crash.
    * On one occasion the entire system froze, forcing a hard reboot.
    Note sure if the helps or not...as I never use Dither.
  2. #192
    Ok... good detective work... I am able to duplicate the crash if the Random Dither option is selected.
    Naturally Digital... Are you using that option... if I turn that off... all is well.
    Looking into it now.
  3. #193
    Toronto Canada
    2,880
    Yessir. I have that option enabled.
    Yaay! Thanks Bob, and thanks Dell. I'm glad we've identified this. Persistence pays off!
  4. #194
    Ok... fixed the code... have an update almost ready.... in the meantime... turn the random option off and then see if everything is stable.
  5. #195
    Toronto Canada
    2,880
    Great! Thanks Bob. Will do.
  6. #196
    Mar 2005
    Stuck in FL for now...
    2,771
    Default Select Mode bug?
    I noticed that when I have a lot of tracks in the MT zoomed to see all of them and go into Select Mode I can not left click and drag down to select tracks. Here is a link to a video showing what I am talking about. https://www.youtube.com/watch?v=RTokblWA-u8
  7. #197
    Micro,
    Sorry, do not see any image...I believe that thee are still issues with the Forum allowing for the uploading of images...
    In my meager test...I display 20 tracks, enable [Sel], left-click Track 1 - and drag down to Track 20...all highlight as expected.
  8. #198
    Default Re: Select Mode bug?
    Not a fix (I also don't see an image) - but as an alternative, don't forget that you can select the first region and Alt/Click the last region you want to include across and down the tracks. In fact, you can Alt/Click the MT space after the last region, in case the region you need to click is too narrow/short for you to clearly see at your zoom level.
  9. #199
    Mar 2005
    2,771
    Micro,
    You do not see the YouTube video I posted, I did not post an image?
    Here is a link https://www.youtube.com/watch?v=RTokblWA-u8
  10. #200
    Micro,
    ...there is just a black square visible...so we are unable to see just what the item is supposed to be!!! Are you not seeing this on your end?
    However, I just added twenty SoundFiles to the MT, enabled [Sel] - and again, all is working as it should.
