The failed SAW mixes were 24bit.
The waves that crashed SAW are 32bit
Also a 16bit AIF file crashed SAW.
I am sending you a link to the problem files in an email Bob.
16 bit mix of the same EDL compiles with the same pause in the counter, but the resulting file doesn’t crash SAW on playback.
The percentage meter works fine when all plugins are removed.
Okay, tried it with a different mono wav file. Fresh session, no plug-ins.
Build Mix happens the same (although faster). (See my previous post - appears to be the same.)
I also noticed that as the source file is imported, the percentage bar only gets about a third of the way through, and the percentage window gets really wonky, but seems to display similar problems. It goes so fast, I can't really tell, but it seems to go through a couple of resets, and ends at about 18%.
Hope this helps.
Roger
Roger,
Are you, by chance, using an nVidia graphics card... we have discovered that the graphics driver may be the case of the dialog bar weirdness.
In other words... the process continues normally in the background and it is just the display of the percentage bar dialog that freezes.
Currently looking for a solution.
In fact, I am.
Thanks.
Roger
Hi, Bob. To test it out, I loaded 64 onto my Alienware laptop, which has Intel graphics video.
You're correct, the progress readout works fine on BuildMix.
But ... when I imported a WAV file to test, the import progress bar and readout displayed the earlier wonkiness. It went pretty quickly, but it reset to 0 midway at least once - maybe twice. As I mentioned before, it seemed to do the same on my desktop, which has nVidia graphics.
Hope this helps.
Roger
Hi Bob,
The plugin of Acustica Audio quits once it is inserted. I can only open it via Jbridge but it is not as efficient as in Reaper doing at the moment. Please check their plugins when you are available. I knew that they'd contacted you several years ago, perhaps you can communicate with them direct.
https://www.acustica-audio.com/pages/aquarius (have to create user account on the page before download those (trial) plugins from Aquarius)
Thanks!
Ok... the graphics driver lead was a wild goose chase... I believe I found the problem to the progress bar dialog issue and am creating an update to fix it.
New update V1_0a is online.
