HimHui,
Which plugin of theirs... Aquarius is an installer application, not a direct plugin from what I see.
Also... they do mention that the plugins might need to be set to run as administrator in order to run correctly.
HimHui,
Yes, Aquarius is an installer app, u can download any trial versions there but you have to create a user account first. All plugins have problem to open in Saw64 (i am not sure how to run their plugins as administrator cause it is a dll file, anyway Saw64 is run as admin). You may download the small size one such as Ei Rey Comp (trial).
Make sure you have installed the 64 bit VST2 plugins... not the VST3 or the 32 bit versions.
Hi, Bob. Yes, the BuildMix progress window seems work fine now with 1.0a.
Thanks!
Roger
Bob ,
Just installed 1.0a. Still have no tempo sync on the Toontrack Instruments (EZ Drummer ,Superior Drummer 3 , EZ Keys ). Was that addressed in this update ,or not yet ?
Always look at the latest release notes for each update from the Info Menu inside the program... it will tell you what has changed.
No... I was chasing other more drastic bugs.
Hi Bob, the only plugin I cant get working on Saw64 is Drumagog 5. I have installed the 64 bit version of it a few times and checked everything I can. Saw64 freezes then shuts down when I try to load it. All other 64 plugins I have loaded including Waves and Slate Digital are good.
Cheers
Bruce
