Results 1 to 6 of 6
Thread: USB connection
    Jul 2005
    The Rolling hills of Central Pa.
    177
    Default USB connection
    I have a small Roland keyboard with a usb out . How can I connect with Saw using the usb? Thanks
    3,526
    Default Re: USB connection
    Kimbo,
    ...It might be helpful if you provide the model #.
    This being said, USB-powered devices will generally have device drivers that you install to make that device available to the operating system. This device will then be displayed as an available MIDI device in the applicable software application being used.
    Hope this helps?
    Quote Originally Posted by Kimbo View Post
    I'm curious. Is the USB, here, for MIDI or audio? Or both?
    If there's audio functionality through the USB connection, much as Dell said, you would want to install the audio device driver for the keyboard. Whether MIDI or audio, be sure to follow the manufacturer's driver install procedures, then the virtual device (MIDI or audio) will appear in the appropriate preferences selection section in a program like SAW.
    Mar 2015
    Alberta Canada
    79
    If your keyboard can be used as a midi controler, you may not need a driver, the software may be built in, and will reconize and can be used by a midi application. SawStudio can handle midi in a couple of ways....I suggest you check out Microstudio's youtube page...I learned a lot from it...
    https://www.youtube.com/user/Learningsawthedaw/videos
    .....I suggest you read the manual for your Roland keyboard.
    Laughing Crow Studios
    Alberta Canada
    The key phrase here is "class compliant". If a USB device is class compliant, the necessary driver will automatically load when the device is connected to your computer, so there is no installation procedure necessary. I recently bought a Alesis controller keyboard (just midi, no internal sounds) that is class compliant. When I connected it to my laptop, it was immediately available, and could be accessed by SawStudio.
    Cary B. Cornett
    aka "Puzzler"
    3,526
    Cary,
    ... Good point, Cary! Glad you brought this up. But, may I ask where is Kimbo?
