Results 1 to 5 of 5
Thread: Install problem
    Oct 2005
    Tehachapi Ca.
    537
    Default Install problem
    I was having a problem installing SAWStudio ver. f to my existing SAWStudio64 folder. Installer couldn't find the .exe file until I renamed it, putting the .exe on the end. But it has been starting the program just fine...go figure.
    Default Re: Install problem
    The installer seems fine here... my guess is that you may have had SAWStudio64 running at the time you tried to use the installer... I would try again, making sure SAWStudio64 is not currently running.
    Oct 2005
    Tehachapi Ca.
    537
    I got it to install by renaming the SAWStudio64 application file by adding the .exe to the end of its name.
    It already should have the .exe at the end of the name...
    Oct 2005
    Tehachapi Ca.
    537
    I know. Weird. But once I added a .exe, it installed over version e, that's all I know.
