I looked at a lot of options to get CPU affinity to work. There may be other options, but Lasso was the only one I could get to function reliably.
I've pretty much turned off all the other functions and am really only interested in the CPU pinning and Process Elevation.
I'm not doing anything to the SAW Studio process so it runs as its default process level and can use both CPUs.
Process Lasso lets you easily select CPU affinity and process level and set them to always use those settings. (image below is just to show the Process Lasso interface) You can see the Priority Class and CPU affinity options, where it will either show you the current setting or allow you to always use a particular configuration.
