Question concerning the SAC Link using SAW Studio 64 and SAC 32. When I upgrade to SAW Studio 64 will the SAC Link still work using SAC 32 or will I need to also upgrade to SAC 64? Thanks.
_____________
William Bushnell
_____________
William Bushnell
William,
... Just tested this out...both have to be the same "bits"...Question concerning the SAC Link using SAW Studio 64 and SAC 32. When I upgrade to SAW Studio 64 will the SAC Link still work using SAC 32 or will I need to also upgrade to SAC 64? Thanks.
Ok Thanks, I ill need to upgrade both SAW & SAC. Sorry if this has been answered before, can SAW 64 use SAW 32 EDL's?
_____________
William Bushnell
Yes... you can open SAWStudio32 edls into 64... but once saved in 64, you can not go back... so keep copies of the 32 bit edls if you think you need to use both versions.
Remember... 64 needs all 64 bit plugins as well... unless you use JBridge or some other 32-64 bit wrapper.
Thanks Bob, I'm presently using jBridge to use several 64 bit iZotope plugins in SAW 32 but I can see the need to upgrade SAW, SAC, and RML plugins to 64 bit.
_____________
William Bushnell
