Hi all - I've just set up a new laptop (Toshiba L850 with 8 Gb memory) with Win 10 64 bit on it and I'm getting quite a bit of weirdness with plugins.
Some I've sorted out by placing the dll's directly in the SS VST plugins folder, rather than using ini's.
But I'm having a problem with these messages popping up. (SAW 32 bit on Win 10 64 bit )
" Trouble Creating or Opening File for write operation.Check track label for illegal file name characters.
Make sure there is enough disk space for the operation."
"Trouble writing undo file.
Make sure path is valid and not write protected."
The plugins still load after the messages and work fine.
I'm assuming it's a caching problem but thought you fellas would have come across this ages ago when a lot of you switched to 64 bit OS's.
Thanks
