Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: VI’s in saw64
    3,526
    Default Re: VI’s in saw64
    Microstudio,
    All it means is that you choose Pre when adding a VST/Effect to a channel. In each channel, you have a choice of inputting a VST/effect either Pre/Post/F-Res
    ... Thanks for the update. Much appreciated.
    However, would this selection not be the default for most situations?
    2,431
    Not if you I use latency inducing plugins. Putting them pre fader makes automation moves not line up with their placement. If you use the plugin post fader, automation stays correct. For me, I can use non latency inducing plugins pre fader, latency inducing ones post fader.
    For work with a VSTi, the track fader won*t affect the volume of the synths output unless placed pre fader. Or, you could place post fader and then route through a sub master and use the volume on the sub master channel.
    Mar 2005
    Stuck in FL for now...
    2,771
    Microstudio,
    SawStudio does not have a default for this you just choose what you want for each channel.
    I've never used a Vst-I. What can you automate? ...or are your pre/post automation concerns just in general.
    I'm kind of a lightweight in the automation department - usually just a bit of fader and pan, so haven't needed to explore all of the side effects. Are you saying if I add or remove say a vst that reports some latency in the pre patch point, it effectively shifts previously set automations?
  5. #15
    Mar 2015
    Alberta Canada
    79
    Dell...I'm talking about VSTi's(SoftSynth)...normally you would patch a general VST post fader, to help control the overall level of the track.
    What I was refering to is the SAW FX patch 'pre/pst'. My understanding is that your VSTi(SoftSynth) should be patched Pre-Fx, so you can take advantage of the 'Pre-Fx Patch Signal Flow =>>>', under the Mixer Menu, this will allow you to use Dyn/Eq, on your VSTi.
    Compared to you and Micro and many others on the form...I'm pretty much a MIDI idiot...don't use it much...find parts of it confusing...just push through, and hope I get a noise...my understanding of Rich's question, was not a MIDI question, but a volume issue.
    Laughing Crow Studios
    Alberta Canada
  6. #16
    Mar 2005
    2,771
    I have never had any problems with latency patching in a VST/Plugin PRE?
  7. #17
    It's not a "problem" with latency MMP was talking about - so much as a known difference in how plugins that induce latency (and many do - such as SAW's own Levelizer in peak limit and normalize mode - and yes, I realize it's NOT a VST plugin) will affect the sync of automation and regions on the MT. In pre position, they won't stay aligned, but they will in post position.
    If you don't use automation and a pre-position latency-inducing plug-in together, then you probably would never know there's a potential issue. (forgive me, if I don't remember offhand if the plug-in and automation have to be on the same channel, or the offset applies to all automation in the session. I don't generally run into this issue, myself.)
  8. #18
    2,431
    Yes, I am talking about track automation. In the pre patch point, the latency of the plugin affects the timing of the automation on the track. So volume, pans, EQ changes etc are misplaced in the time domain.
