I didn't listen to it a lot, but I really liked the quadraphonic experience back in the seventies when I was lucky enough to get it. I think it's inconvenient socially though. There's only really one place in the room that's in the sweet spot. If you were in your listening room alone, and/or using quad headphones, it would be perfect (actually - I've never listened to quad headphones, I just think I'd like them) Otherwise, in a living room equipped with a quad system with a number of listeners: most of the listeners wouldn't be getting a quadraphonic experience. It would be like listening to stereo but not being in front of and in between the speakers: the music is still there but there's no placement of instruments and no sound stage. Instead, it's a distorted, mono, experience dominated by whatever's on the side with the speaker you're closest to.
I'm not sure how they encoded them, but my acquaintance's system played special vinyl and used a decoder. And the result, if you were sitting in exactly the right spot, was sometimes being in the middle of the musicians. Each of the speakers had it's own unique program. It was not at all like actually being on stage with real musicians though because in a real performance the musicians would be pointed to the audience and you often can only hear some of the other instruments via monitors. Whereas his quad records had them apparently surrounding you at a balanced equidistance and pointed toward you. Playing just for you. So, you could place and hear everything perfectly. Still though - move a few feet in any direction and the effect was gone.
