Dave, you're really renaming all regions to the same name. But, in my case it worked for me, because all selected regions were from the same filename I had changed, so typing in the corrected file name (with a preface) then changed all the regions (which looked like all were individually changed... but they were the same name anyway - I just changed the preface)
You can't rename only part of each region name of multiple region names - they will all be renamed to what ever you're typing in the rename box. (sorry I wasn't clear on what I was doing in my renaming my regions).
There is only one dialog box for the rename.... so however many regions you are selecting in the Regions dialog box, all (each) will be renamed to the new name typed (with corresponding "001, 002" etc.).
