I'm doing research on guitar pickup systems. As it turns out, they have an internal resonance that is created by the inductance of the pickup coil, and capacitance in the circuit. What I'd like to do is output some pink noise from a SS recording and run it into and out of the pickup circuit and then record that result back into SS with a frequency analyzer that I put on that channel. What I'm hoping is that the circuit resonance will visually show up as an aberration to the pink.
However, I don't want to melt the pickup circuit or, you know, damage it somehow.
And I'm not very savvy about the composition of the types of electrical signals I routinely use in the studio. Up till now, I've used them and ignored what they represent. But I'm sure that, like a mic, a guitar pickup must be a relatively very weak signal and so damage to it might well be possible.
So, my question is, what do I need to do to make a signal coming out of my d/a 'appropriate' to hook up to both leads of a guitar pickup/pickup circuit?
I'm in the planning stages right now, so it would be a little while before I actually did it. But at the moment this is the sticking point in the diagram 'where magic happens'. I'm hoping there's a way that won't damage either my equipment or the pickup/circuit. Anybody feel like they understand the electrical environment at hand well enough to give me advice?
